Old Oct 3, 2017 | 08:24 PM
James1549
Default Rocker panel cleaning today
Thanks to the PDF, removing the rocker panels are fairly easy.
Before
After. I had some wheel cleaner that someone gave to me that I don't use. But it works great on rocker panels. Wheel cleaner, a scrubby, then some polishing compound, then wax and almost brand new.
While the panels are off, this is a good time to blow out leaves and debris from behind your fender. I used an air gun from the wheel housing and also from the door opening.
I wiped down the hidden parts of the body with some Express Wax.
This has to be the best the rockers looked since I have owned the car!
