Mounting. The Pyles don’t fit in the baskets. I am not comfortable mounting them at an angle with fewer than four screws. It might be possible to find spacers and longer screws so that the speakers could be mounted parallel to the shrouds, but it would be time consuming to find or fabricate the spacers. Also, there is the risk of not finding a workable solution. That leaves the option of cutting the baskets. My belief is that the fit problem is due to the wider diameter of the Pyle’s magnet and that a single V-cut in the speaker shroud will allow proper mounting. I don’t think that the depth of the speaker will be a problem, but cannot confirm until I do the cut(s).
If you cut a hole into the speaker shroud, that will cause a loss of output due to phase cancellation issues from the back wave interfering with the front wave. The hole would have to be resealed with tape or something. I'm currently working on getting the Pyle subs to fit using a modified 1/2" spacer
More to come.
