Needs Trans Work/ Salvage Title 2005 Xfire Limited, nicely modded
I am selling my baby, shes not perfect, but she is far from finished being a fun car for someone. Blaze Red with Black Top lowered 1.5 inches.
$2000 Takes the Prize.
Parts are for Sale Too but I'd rather sell it all at once.
Too start shes been in a fender bender or two but fixed nicely a couple of times.
Right now, she needs a new hood and two front fenders, and possibly a bumper cover.
Also, two bolts that hold brackets near the transmission under the car are missing. I don't know how it happened but the car should prob get a transmission. Maybe a couple of bolts and some fluid would work for now, but I think the transmission is cracked. Interior is in rough shape but most everything else works.
It's parked with 183000 miles.
She has Eurocharged tune and stock map available for this car.
She has needswings single cold air intake.
She has TB upgrade
She has Magnaflow Muffler resonator delete custom exhaust.
Kenwood BT Marine Radio Perfect match. All speakers Upgraded including Pyle Sub Woofer and 3ohm door speakers, upgraded same brand that came stock with the car.
Top works perfectly and defrost.
Driver heated seat dose not work, passenger seat bottom heats.
All synthetic fluids Amsoil.
New Control Arms with KMac Camber/Caster Adjustments installed. 1000 miles on them.
KYB Gas AdJust for Xfire in all four corners 60k on them
Ebiach lowering springs 80k
Ground control camber adjusting rears
Ground control adjustable sway bar links.
Drilled Rotors front 6000 miles
New standard rotors rear 15000 miles
New brake pads ceremic 15000 miles
New steering gear inner/outer tie rod ends 8000 miles
Front and rear spacers that take the wheels the fenders edge, I don't recall the brands but the fronts were a ***** to get!
New Black Lion Tires Fronts 2000 miles
AMG 550 engine and trans-mounts.
flex disks need to be replaced and prob the center pinion bearing.
headlights are functioning but are in rough shape
1 fog bulb needs to be replaced.
$2000 drives it away, straight to the transmission shop.
[/RIGHT]
