Old Oct 10, 2017 | 01:07 AM
  #293 (permalink)
alexdc's Avatar
alexdc
Default Re: Valve cover leak...
The line you need to remove is the gas line to the fuel rail. Get ready, about a cup of gasoline is gonna drain from the rail when you remove it. I used a couple of rags to soak up the gas. BE CAREFUL! You do not want contamination in the line, as there is no filter between that point and the injectors.
The hose (Which is a vacuum line) I THINK you can replace with generic hose of the same inside diameter, use hose clamps, I know they didnt' when they built the car, but do it anyway.
Just download it from our tech section - but don't have high hopes, the service manual is less than what I expected, and I expect so little - being divorced twice.
GO here:
https://www.crossfireforum.org/forum...ollection.html
So do you remove it from the top of the engine?
Should I do the spark plugs too? Is it easier to change them with the valve covers off?
