Old Aug 1, 2006 | 09:39 AM
adoni's Avatar
adoni
Default Re: Condensation on the inside of windshield
Originally Posted by Sennaspirit
Exactly MAYA...that's what I found (by mistake) I had the Vent selector set to the defrost mode (12 o'clock) with the ac running. If you put the selector to vent down (at your feet) it will reduce or eliminate the fogging.
Also, I'm going to buy some RainX (interior) to coat the windows when the weather changes in the fall. This will also help with "fogging" issues. NOTE: this is not the same as regular RainX, which you use on the exterior side of the windows.
I use the face selection because cold air sinks. By pointing the vents upward if creates a circular flow and cools the upper portion where the hot air is anyway.
On the getting out and glasses fogging ... that's nothing new. Where I work they keep the A/C so cold I leave the office to go to the shop ... instant fog.
It's also a good thing when getting in the hot car to use the recirc and get the hot air out of the car, it aids the cooling and the interior isn't hot for long.
