Old Oct 15, 2017 | 08:21 PM
onehundred80
Default Re: Super Charger Not Working?
Originally Posted by Tar Heel David
I had the same problem and changed the pump. Same thing happened Again when the supercharger got hot. There is a good description with pictures illustrating how to wire the pump to cut it on when the ignition is turned on. It works great all the time. I believe there is a heat sensor that is bad, not the pump.
Check out the forum for how to wire the pump on with the ignition. It only takes a short piece of wire and terminal connectors. If it doesn't work, the connections are easily removed.
Good luck.
CLICK for the thread mentioned above.
