Old Oct 28, 2017 | 01:03 PM
Steve Jr's Avatar
Steve Jr
Default Re: Right side marker and right tail light out
Originally Posted by White Thunder
So l have the right side marker and tail light out everything else is ok put a new fuse in and it blows right away ....any ideas what l should check next??
Check the sockets, that receive the bulb. Look for discoloration caused by the bulb getting hot or shorting against the socket. Replace if needed. If you turn the light switch past 12 o'clock, to the left it will light (depending on which detente) ,either the the drivers or passengers marker lights.
