Originally Posted by HDDP
Would you like me to take a photo of the fuses for you ?
Yes please if it's not too much trouble. By the way I did a search and found this post, is this correct guys???
USE THESE INSTRUCTIONS AT YOUR OWN RISK. FOLLOWING THESE INSTRUCTIONS MAY RESULT IN AN UNSAFE CONDITION AND MAY VOID YOUR WARRANTY.
1. Locate the Engine Fuse Block. It is located to the right rear of the engine compartment in front of the battery.
2.
Open the Engine Fuse Block Cover and locate the ABS System fuse. It is the #3 Fuse. It is the MIDDLE fuse and cable between the 2 black cables. It is a 50 Amp fuse.
3. Using an 8mm socket remove the nut holding the ABS System CABLE. It is the one that does NOT have the long silver bar under it.
4. Remove the cable from the bolt. COMPLETELY wrap any exposed metal on the cable in electrical tape.
5. CAREFULLY bend the cable back on itself and tape the now wrapped end connector to it's own cable or an adjacent cable.
6. Put the nut back on the bolt and tighten it up you might want to use a little loc-tite to keep it from rattling loose.
7. Close the Engine Fuse Block Cover.
8. Close the hood and drive the car.
Disabling the ABS System in this way WILL illuminate the Amber ABS System Warning Indicator Lamp and the Amber Brake Assist Warning Lamp located on the bottom right side of the Instrument Cluster.
There is no fuse to disable these lamps. You will need to remove the lamps from the Instrument Cluster to disable them.
see attached pdf's for pictures.
I DO NOT RECOMMEND DISABLING THE ABS SYSTEM.
