Re: Custom Tailight wiring.
I was able to pull it up at school using shop key pro.
So what I did was bridge the brake light + wire to the blinker + wire.
Its pin 3 to 4 on the harness connector.
Only thing now is my blinkers turn on when I brake as well the indicator on the cluster.
What I need to do is install a diode on the blinker wires so that current can't travel up to the pcm and indicator lights but only current going to the bulb.
