Old Nov 13, 2017 | 01:38 PM
Speedy4x4's Avatar
Speedy4x4
Default Re: Rear main seal and clutch replacement?
Originally Posted by dylan07
How do I check the fluid level? Is there a drain plug and a plug that the fluid leaks out of when it's full?
there is a drain plug on bottom and a fill plug on the side, one is 17mm I believe but can not remember the other, I didn't have a metric Allen that big, so I took a metric bolt and nut, welded the nut on and not I can use a socket.
I use royal purple in my 6 speed.
if not changed before I would definitely do it.
