Re: traction control
So the front wheel speed sensors are the key to the good dyno run...? Would it not be fairly easy to wire the sensors in parallel with the rear wheel sensors (and using a resistor) to simulate all 4 wheels turning the same speed. This would get you a good dyno run over 5,000 rpm?
