Padgett
ps fuel pressure when running is a bit over 50psi and stable MAP is varying with load.
Have you changed the injectors? I went to 550's and I have the same issue, codes only after idling awhile. I have an Ultra gauge so resetting is easy. I believe that the issue is the bigger injectors can't deliver a small enough charge so it's just a bit rich at idle.
