Re: Crossfire will not start!
I did not notice the check engine light being on when I last ran it. As for the fuel issue I did disconnect the fitting at the fuel rail and placed the end in a container and had someone turn the key on and no fuel. There was no fuel when cranking as well. I did check all fuses and there is power to them and none are blown.
I will unplug the sensors and use the contact cleaner as well.
