Re: Crossfire will not start!
I did check the RCM and with the key on the engine control relay activated but the fuel pump relay did not. I manually activated it but still no fuel at the rail. I even tried the re-solder fix of the three contacts on the RCM. All fuses are good and there is power to and through all fuses. What do yo mean by an open coil?
Disconnected the crankshaft and camshaft sensors and sprayed contact cleaner (they looked immacualate).
I will have access to a code reader in the next day or two and will check for codes.
