Old Nov 25, 2017 | 11:01 AM
  #145 (permalink)
onehundred80
Default Re: parting out 2005 SRT 6 convertible
Originally Posted by John&Terry
Thank you, I will keep that solution in mind. It appears we have found someone with a salvaged connector. So, now I will swap the pins out, if possible. If that fails I will try a Napa type H7 connector.
I watched a you tube video that said to grab the connector with pliers and pull it off when changing the headlamp. The end result for me was a cracked connector. Won't do that again!
If you just grab a single edge it works, do not grab too hard though and pull straight out.
