Old Nov 30, 2017 | 01:13 PM
onehundred80
Default Re: Aerofoil engages on engine startup
Originally Posted by geofffenton
Just an update. Haven't replaced battery yet but do plan on doing.
Was intending to trickle charge battery overnight but it was fully charged within 40 minutes. It is a 74 Amp Hours battery. Acid levels were slightly low and have been topped up over the plates.
I use car 3-4 times a week. Normally there are 3-5 trips on each of these days ranging from 1/2 mile to 2 miles, on slow, busy roads.
I notice that I do tend to use a high gear while driving, mostly under 1500 rpm except on acceleration to next gear. I've altered my driving this week so that I remain in lower gears to get higher rpm.
Each day I use the car the Aerofoil raises on 1st startup but doesn't normally on subsequent startups especially if short time since previous use.
Engine continues to start 1st time, always (touch wood).
If the battery charges that quick from a flat condition it is toast, so save time and get a battery.
