Old Dec 5, 2017 | 05:05 PM
onehundred80
Default Re: Some uses for the old oil change O rings
Yea, but since the manifold is bolted to the engine that averages 190 F, there is bound to be some heat buildup.
What I can't figure is that this same O ring is in the oil filter assembly that also averages 190 F, so why wouldn't it deteriorate there too ?
The oil filter O-ring is changed once in a while, the throttle body O-ring hardly ever if at all. The filter O-ring is also kept moist, maybe that helps.
Remember the O-ring in the dip stick tube that was brittle a week or so ago?
