Re: Heated seat issue
First I would check the voltage at the seat. You will have to remove the bolts to the seat to access the plug. If there is power then most likely the seat heater will have to be replaced. Then I just bought a new aftermarket seat heater pad and wired it in. It does take some time but is doable for the do it yourselfer.
