Originally Posted by woody
Hmm, could be, but the system has 'dual redundancy', i.e. two independent position sensors on the pedal and butterfly, so both would have to be faulty. Could be the motor or harness though. I don't know why they can't just hook up a standard OBDII logger.
Even if there aren't any codes being thrown you should be able to get some clues from the logged data traces (revs, ignition, speed, fuelling, throttle position etc.) what is happening.
Good Luck Sharon, hope you get a solution soon!
Since it's a throttle by wire system, it will have both a tps on the pedal and on the throttle. That's the minimum required to function. I'm not aware of two sensors on each end.
I spoke with one of my shop foreman and he's not aware of a Mercedes specific data logging system. However, he mentioned that one of the culprits that he's seen in this situation was a bad air flow meter. His experience involved vehicles with the exact same symptoms.
