Old Dec 17, 2017 | 08:36 AM
king happy's Avatar
king happy
Default Building lightweight Lithium car battery 10lbs!
Decided to put princess on a diet and install a lithium battery . I have been installing large lithium packs in gem cars for about 3 years and have learned a lot about different types of lithium and their characteristics . The lithium cells we use in Gem cars are Lithium manganese (LMO) same chemistry as Nissan leaf , chevy volt , bmw , etc. They work well in these applications but they don't like heat and started losing range after a year in hot climates . So I started researching a better chemistry and found Lithium Titanate (LTO), this is stuff is incredible ! These will run circles around any other lithium .
Here is some info on them :
A lithium–titanate battery is a modified lithium-ion battery that uses lithium-titanate nanocrystals on the surface of its anode instead of carbon. This gives the anode a surface area of about 100 square meters per gram, compared with 3 square meters per gram for carbon, allowing electrons to enter and leave the anode quickly. This makes fast recharging possible and provides high currents when needed. (from wikipedia)
these cells can be charged/discharged at 7c with short runs over 10c . Battery can be charged to 90% in less then 10 min.
They perform very well at low temperatures and extreme temperature tolerance from -22 degrees f to +131 degrees Fahrenheit . Most other lithium's well either not perform or quickly degrade if operated in these temperatures .
They are very stable and considered one of , if not the , safest of all lithium's . we have test data showing them charged to TWICE their normal voltages with no thermal runaway , and they continued to function properly .
25+ year shelf life
20,000+ life cycles (charged and discharged twice a day would be 27 years!)
LTO can be stored at 0 volts . ( there is a test online were they stored them over one year at zero volts and after 1 year there was no lose of capacity ) so if you have an application were there is a deep discharge or storage without the ability to keep on a charger these will work great. Other lithium's will be permanently ruined if they were to go below there minimum voltages .
The only problem is that they're not available to the public and if you could buy them they are EXTREMELY expensive . But we got lucky. Altairnano wanted to sell some old stock they had (sizes they are no longer selling) so we bought all of it (about 12 pallets of them, mostly the larger 55ah cells , but 2 pallets of the smaller 11ah cells).
I've really wanted to build one for my crossfire and finally got a chance . It takes 6 cells in series to get the proper voltage and decided to double up on them for more capacity (12 total 2p6s)
the stock battery weights 41lbs , this one weighs 10lbs
stock battery has 680cca's this one approximately 1200 cca's
stock battery life span 4 years ? This one 20+
