Re: Convertible top --- yikes!
Got a code reader? Find a shop or fellow Crossfire Owner who has a reader that can scan the DRB III info. Betcha it is the problem I described in Post 18 (October 24). Simple to check. Just remove the cover on the inside of the trunk lid, disconnect the described connector and see if the top will go down. Don't forget to close the trunk lid before trying this. I have checked numerous trunk latches and all of them have the problem with the switch. Takes less than 15 minutes to check --- might save you 152 miles, but again 152 miles in a Crossfire is not a bad thing.
