JustinX
My crossfire is also stuck in park and will not start. Just had the rcm fixed and has a new battery. The shift indicator is showing a block instead of the P. Do I need a new shift assembly? Worked fine until the rcm was repaired. Turned key on while rcm was being fixed to move it out of garage. Wing went up and the shifter locked. Can be put in N by pressing the release through the trap door, but locks up again soon as it’s in park. Paid $2500.00 from a friend who said the car was not reliable. I read the forums and thought I could fix. If it’s the computer will just push outside by a barn and let it rot.
You turned on a car while a major part was missing, I can see problems occurring after that.
Hook the car up to a code reader and see if any error codes have been set.
That’s a good place to start.
What year and how many miles on the car? They are quite reliable, you should have come here first as there are many who have solved problems for very little to no money that the dealers etc wanted a fortune to fix.
