Old Dec 30, 2017 | 09:50 AM
onehundred80
Default Re: stuck in park???
Originally Posted by Padgett
Mercs are different (and the Crossie is really a SLK320/R170.
Torque Pro & the Actron cp9180 OBD will show generic OBD-II codes but you need a real Merc scanner or a specialized indy (like an Autel DiagLink or iCarSoft MBII) to read the internal codes since Mercs save everything.
Still, if TCM (tranny module) is not releasing from Park and there is no dash display of gear, sounds like no CAN-bus communications and a code should be being set as soon as it starts. (Never say never).
Spilled some water in mine and until it dried out was acting just like
The TCM is by the amplifier in the passenger foot well. You probably spilt water on the gear shift which is a delicate part with moving contacts.
