onehundred80
Your problem lies in #2 and #4, they did not shut down, they were just not firing to spec. Switch the coils to other cylinders and see if the problem goes to the new cylinder position. switch the cables later if the problem stays in the #2 and #4 spots. Check the plugs as well.
It could be the injectors plugged or failing, but try the coils first. Looking at the plugs could give a hint about the injectors condition.
Sorry, what I am trying to say is all 6 cylinders fail, but it's rarely the same ones twice in a row if I clear the codes... It will be any random combination of 2 or more of the 6 cylinders that flag a fault code... Could it be that all 6 coil pack failed at the same time!?!?
