KW springs
OK, I got a KW spring set because they state you can adjust the height of there springs. Well I just spent seven hours getting the right rear spring off! So I start to put the new spring in and the rubber seat that goes in the upper mount does not fit on there adjustable perch, I happen to have a used front rubber seat with the three ***** and it is bigger than the rear one. Also no ***** on the rear one. Since the instructions suck and are so generic they are worthless, has any body used these springs, I went with them because of the adjustability BUT they will be all but impossible to adjust on the car! It would have been just as easy to get a fixed set (and much cheaper) and swap them out with the stock ones for track weekends or just run all the time with the lower springs.
So for the folks who have put in rear spring can you go without the rubber seat or will it be real noisy with the spring sitting against the body?
Any experience with the KW spring set.
