Padgett
2004 had this problem. Someone here will know the fix. Never had a problem with my '07 popping out.
Even the wranglers have same problem, with there longer shifter.
After I had it happen and just changed how I shifted and no problems, I drive severAL different manuals all the time, like today a eaton 10 speed, and tomorrow will be a 8 speed, and both of those if you use clutch while you shift, you will not get into gear and use clutch only to take off.
