Re: 05' Crossfire Won't Crank
Would wager that there is a trouble code set that will point to the problem but need someone with a scan tool that can scan a Mercedes R170 (16 pin).
Find an indy who can read merc codes and you have found your car's new best friend.
Steps: Sounds like you are North of St. Augustine so about 100 miles from here. If you have an automatic, it is only supposed to start in Park or Neutral or do you mean you push the lever and it starts ?
