Old Jan 19, 2018 | 03:33 PM
Padgett's Avatar
Padgett
Default Re: stuck in park???
"The key was turned on while rcm was out of car. The wing deployed, tow and traction control lights started flashing." Mercs really do not like being on with a low battery. Last one I saw like that had over 30 codes stored that had to be cleared.
"The shift indicator is showing a block form " that usually indicates a lack of can-bus communications with the shifter module. Even Torque Pro should show a P06xx and/or P07xx error. Actual Merc codes will be different.
