Motorman
Hi folks I solved the problem but though I would post up for reference
I ordered a replacement brake switch from flea bay, duly arrived but not until I was under the dash did I see it was wrong, switch supplied was for four wire set up, so duly returned switch and sourced the other one, arrived installed I didn't expect it to work as it was two wire but hey presto job done.
If I press the brake pedal I can just about hear the click of a relay under the dash so somewhere back up the loom is the park lock wiring so must have been the switch after all
What a pig to fit rolling about under the dash cracked a rib on the door cill as I attemted to extract myself from the ungodly position
Sorry to hear about the cracked rib, you solved the problem that is the good thing.
Thanks for the reply, too many never bother to give any feedback.
