Re: auto box problem
Think one element may be the dash indicator. If it comes up with the "P" when you turn the key on then it is communicating. If not it stays a blob. Second indicator is if you use the manual release and it slips into drive/revese it is talking. If a jerk it isn't. Final clue: if once in drive it shifts through the gears, it is communicating. If stays in 1st, it isn't.
Finally a bad shifter will probably set codes, faulty brake switch may not.
ps if I park with the top down, I put my hat over the shifter to keep water (rain, sprinklers...) out.
