ccoverley@aol.com
There are at least three operations, probably more than 3
Changing the mirror stitch
Replacing a broken cup holder
Replacing the cup holder with the small bin
I have just changed the cup holder for the small bin
Mine is a manual
Pull the gear stick cover up (not off)
Lever up the gear stick surround
Undo the two Phillips screws which appear
Pull the back end of the storage bin carpet up to uncover two 10 mm nuts
Remove the gear stick rubber sleeve - it will come off, just a bit tight, use WD40 or other to loosen if neccessary
Move the centre console vertical and then you can do whatever it is you want to do
