Old Feb 8, 2018 | 02:38 PM
KDW4Him's Avatar
KDW4Him
Default Re: SRT6 Engine Cover
Originally Posted by paintergman
Are you running the boxes without the inlet tubes ?
I have the inlet tubes also. The passenger side is literally plug and play. The driver side takes a little work and best done with two tubes both cut at the ribs then the longer of each one put back together to form one longer tube.
I bought this pictured set-up from a forum member already to plug on with the clips relocated. Then ordered the tubes. There is a thread here with part numbers needed for the upgrade.
