Scalawag
OK, update on results. No battery draw. Pulled the alternator and had it bench tested, all good. Turns out the new battery was bad out of the box. Took it to advance and they tested it at 12.5 volts and 120 amps. Replaced it and all is good.
i had to replace a battery on my previous car and went to advanced. they have 3 levels of "quality" in their battery line like many manufactures do. i wanted the platinum (or whatever the top of the line was called) but they didn't have one to properly fit the vehicle i needed it for. they did have the mid grade however and i started a conversation with the "tech" who came out to do the replacement. since i couldn't get the top of their line i was a bit concerned about quality. i was told that the lower level battery experienced an approximate failure rate right out of the box (so to speak) of almost 50%. the mid range battery failure rate was approximately 30% out of the box and their top of the line product failed approximately 10%. like many things these days, quality control is minimal if it exists at all, and they would rather replace a bad item leaving the quality control to the end user, than to pay for it at point of manufacture.
