Old Feb 12, 2018 | 10:03 AM
Sik Srt-6's Avatar
Sik Srt-6
Default Re: Supercharger issues on highway
Originally Posted by BoB Fenn
Hello Sik SRT-6,
You mentioned in an earlier reply that using the CWA 50 would require some extra work: "...but require a bit of sourcing for the connector and finalizing the working package." Are you willing to elaborate on the work you're mentioning? Do I need specialized equipment or just a good Meter and test light?
Thanks, again, for all your help so far, and your technical expertise!
BoB
To get the CWA-50 to work, you need the mating connector which you can order from a audi or BMW dealer, I believe the part numbers are located in that benzworld link. Also you need to add a resistor to one of the signal pins to simulate the motor's "enable" command. I will be able to give more details once I get back to my shop later on this week. But if you read thru the thread it will give you a general ideal, if you can read thru the fluff.
