Re: littledummy
Thank you for your prompt reply. I haven't checked the fuse yet , as there are no fuse position diagram on the cover. Need figure out which fuse it is. In addition, the seat does NOT move with the door open or closed. My guess, to begin with could be the fuse. I hope it's that. SIMPLE! Looking into that on the link.
I printed the info from the link, now I just have to do the work. I already have most of the screws out, as I had to remove the sticky ignition switch module because the key would not turn. That was a little tricky, but it works fine now.
I hope this is going to be as easy. I know a little about relays and soldering circuit boards.
Thank you for that info on downloading link, this is really helpful!!
How long does one stay logged in?
