Old Feb 18, 2018 | 05:59 PM
girlgoesvroom's Avatar
girlgoesvroom
Default Re: Key Won't Unlock Door
Nope, I pulled up the trunk floor and everything is nice and dry. As far as I can tell, there's never been a trunk leak.
It does make sense now but in your first past you said the key worked in the drivers door. We have that straight now, it does not lock the car.
When using the key in the drivers it operates an electrical switch that turns on the pump hidden under the trunk mat, it will lock or unlock the doors, gas cap and hatch.
Obviously the pump works so the switch in the door must now have a fault in it somewhere between the lock and the pump. There are a lot of wires connected to the pump and the pump has been known to get severely damaged by water leaking into the trunk, have you seen any evidence of water in the trunk?
