UGH....pulled out my car to make room to install the stereo (just cleaning up some extra room in the shop, we haven't touched the stereo at all yet) (2006 Crossfire)
....blower motor keeps running after the car is turned off. Pulled fuse number 37 (might have been 36) to stop blower motor and once I replaced the car attempted to start twice but stalled right away. Battery was a bit low so I put a charge on it. So when I turn the key on now the fuel pump runs but I have no instrument panel or crank.....all fuses have power....soldering the rcm did not work. It turned over 3x and stalled again right away and then nada. I have drained the capacitors no luck. Sounds like it could relate to the skreem module right? Maybe not tho...we have disconnected the battery, reconnected it, starts now only a couple of times, dies right away and then no crank. I have headlights and radio. No instrument panel lights, locks don't work. I can't help but wonder why all of a sudden the blower and the no start issue.....could this all stem from the blower motor? I know that Chryslers modules/relays etc all work together......Any suggestions we have been fighting with this problem for a few weeks now....tia
15 Comments
