Old Feb 19, 2018 | 03:22 PM
onehundred80
Default Re: blower motor won't shut off leads to no start
You say blower motor, I take that as the heater motor but other think you mean the engine cooling fan?
Here is the trouble code list. CLICK Yours are not on it.
I doubt it is as bad as it looks though.
P2071. Description of the defect. Intake Manifold Tuning Valve circuit Malfunction (Stuck Closed)
P2316 CHRYSLER Ignition Coil 'F' Primary Control Circuit High
P2315 Chrysler Ignition Coil 'F' Primary Control Circuit Low.
P2300 Chrysler Ignition Coil 'A' Primary Control Circuit Low.
P2402 Evaporative Emission System Leak Detection Pump Control Circuit High.
P2561 A/C Control Module Requested MIL Illumination.
File Type: pdf
