Re: blower motor won't shut off leads to no start
the pdf doesn't have a complete listing of codes starting with P2, which I see you did mention...although I did see in your post you addressed the codes seperatly. thank you....I will check which fan I know that fuse #36 shuts it off
I will also try pulling the 40 amp fuse but the rcm has been checked and looked fine
