Old Feb 20, 2018 | 09:12 PM
Speedy4x4's Avatar
Speedy4x4
Default Re: Single piece aluminum driveshaft
Does anyone have a companion flange or 3 arm prop lying around?
I found some ideas I am working with.
1 is I think I might have found a new companion flange that can have common bolt on yoke.
2 is taking companion flange completly off and bolt on a common yoke, but will have to cut off the pilots
3 is custom made yokes front and rear and will not have to cut off the pilots, $125-$140 if they can modify one of there shelf, $170 - $180 If made from scratch and will be direct bolt on, using our normal seals.
4 is solid aluminum bolt on 3 bolt flange, that will be a direct bolt on our companion flanges.
and can have a single aluminum driveshaft cut down and reballanced.
have options for that also.
been working with another senior member on some measurements, but at the point i need a spare flange in my hand.
TY
Speedy
