Re: Single piece aluminum driveshaft
Can a few people help me please.
Help cross reference atleast some part numbers???
From what I have found on acouple sites says the crossfire, charger, 300, and acouple others all use the same 3 arm prop.
Help me double check please with pics and part numbers, counting splines and atleast seeing if the look the same.
And if you find some good pics and post here of the prop for crossfire and from other vechicles and any info you find please.
I have been crawling under vechicles in salvage yards for past 3 days looking at and measuring driveshafts, and if the pinion flange from charger or 300 etc ss the same then I can take one off and be checking and test fitting on acouple other rearends that I am thinking about.
Have a good bead on some aluminum driveshafts with slips that is common and with standars1310 joints with is plenty, if on a modded srt and wants this setup, I would suggest paying more to get stronger 1310 joints, or building from scratch using 1330 or best 1350 joints, but the 1310 is stronger than what we have now anyway.
And with the many vechicles I have crawled under, I might have a idea for a steel shaft that is the right length.
But need some help with info on flanges, making sure manual, auto and pinion on our Crossfires are the same and if the part numbers cross reference and the same on other chrysler or dodges etc.
Than You
Speedy
