Old Feb 25, 2018 | 10:52 AM
JimmyG's Avatar
JimmyG
Default Telescoping steering wheel adjustment lock
I have a 2005 Base coupe and the telescoping steering wheel doesn't lock tight enough and is able to be moved in the locked position. When I pull on the adjustment lever it moves freely and the dash indicator comes on but when I release/push it back the telescoping is much tougher and the light goes out but the wheel can be moved with a little more force applied so the adjuster is working somewhat. Is there a way to adjust the locking/holding force?
