Old Mar 2, 2018 | 09:07 AM
onehundred80
Default Re: Spoiler fault..... any ideas appreciated!!!!
If you look at the switch schematics, I don't see how a bad switch could cause this, unless stuck in the up position? The switch should be normal open. Disconnect the switch and see if your problem goes away.
James
I do not mean just one switch, I am referring to all the switches. There is probably switches of some form in the motor as well. I really have not studied the system. The motor is not just a simple motor if I recall correctly, it may be a stepper motor.
