Thread: Injector Flow %
Old Aug 6, 2006 | 05:46 PM
HDDP's Avatar
HDDP
Default Re: Injector Flow %
Originally Posted by The Toy
This might be for the SC engine only, but they say 40 lbs @ 40 psi an hour.
http://forums.mbworld.org/forums/sho...d.php?t=157851
Hope this helps.
John
Thanks for the info... If my memory serves me, I think the NA injectors are running somewhere in the 67 range.
Hey Woody, do you have those #'s hanging around ? I'm considering running 10% Propylene Oxide in the car, but it is recommended to increase jet size by 2 and advancing timing. If the jets are only running at 80% of capacity, I can safely run the PO with the OEM injectors without burning the pistons and advancing the timing.
