Tofudog90
The stock headlights don't light anything up! The headlights aren't really aren't very foggy at all, but I can barely see 5 feet in front of me. When I first got the car, I was afraid of getting pulled over....Thanks a bunch! - Brian
Did you check and see the bulbs are 'seated' correctly? The low and high beams are 180 degrees out from each other. The little tabs fit into a indent in the headlight socket. If the tab is down, the other one is up (high vs low bulbs). That is usually what is wrong when the member has a concern about not being able to see down the road. Hope it is a simple fix!
