Old Mar 7, 2018 | 10:42 AM
XFireCrazy's Avatar
XFireCrazy
Default Re: Car cut off at stop light
My car would die at traffic lights, when heat would build up at the CPS with no air circulation. After a bit the car would start and run just fine. Replaced CPS and fine. The CPS on these cars are in a bad location for heat.
James
Oops. I wrote that I changed out the PCM, but I meant the CPS. Fixed my original post.
Then again, it was a while ago that I replaced that part. I may try another one if nothing else works.
Oh, I also did the throttle reset as well with no luck in fixing the problem. I'll add that tidbit to my original post as well.
