Re: How to remove the door air line
Found a little in my service manual (bought the CD) which says what not to do but not how to remove the connector. Just "disconnect" is not help.:
"Disconnect the side impact airbag squib harness connector (2) from the side impact airbag.
CAUTION: Do not pull on the squib connector wires or pry on the connector insulator to disengage the connector from the side airbag inflator connector receptacle. Improper removal of the squib wires and their connector insulators can result in damage to the airbag circuits or connector insulators. "
However after some searching I found a picture and it is a keyed plastic (be gentle) two pin connector that must be pulled straight out from the module.
