Old Mar 13, 2018 | 08:41 AM
onehundred80
Default Re: Sloppy steering...FIXED
I would check the ball joints, bearing preload, damping cylinder etc before I saw this as a quick and cheap cure. I am sure they would wear out and affect the steering sooner.
The steering box wears in the area that sees most use, tightening anything in the worn area can lead to overtightness in the rarely used area if it is anything like an old beater I tried this on.
