Old Mar 16, 2018 | 05:12 PM
32er's Avatar
32er
Default Re: intake manifolds
You can see an operating line depending on the sc-map and the assosiated engine suction lines.
In stock you have a more then 3 psi (0.2 bar) higher pressure then nessessary because of the Y construction – no pressure equalisation and way to small dimensioned (15 cm² - one feed). With the crossovers you always feed from 2 sides steadily (50 cm²). (… so the dynamic pressure drops the same as the operating pressure.)
The 3 psi pressure drop on max rpm on a stock car gives you 10 kW (… less supercharger loss) and additionally maybe 1% more volume flow. The pressure drop on lower rpms is far less – because the pressure drop depends mathematically on the square of the volume flow.
Look on the map – 10 kW gain on max rpm; less then 5 kW at 5000 rpm – you can’t find appreciable gains below according the sc map.
So back to my question – many of you tell about the gain on low rpms. How does that work together - the facts: With the crossover you feed far more constant. When with stock imf an inlet valve opens you have a higher initial pressure which drops fast (change from 1 to 2 feed) – maybe you have in stock version more oscillating air that matters – most properly you loose some fresh air to the exhaust? What do you think?
