Old Aug 7, 2006 | 10:23 AM
Aero Blue's Avatar
Aero Blue
Thumbs up Re: I'm on the clay bar bandwagon
Originally Posted by midnightman
Add one more to the clay bar list. I too, used the Mother's kit.
I never used a clay bar before but after reading all the raves, I had to try it for myself and I must say, I'm very impressed. The car is smooth as silk and it wasn't nearly as difficult as I thought it would be.
I just wish it could have gotten rid of the acid rain marks. They are only visible from the right angles, but I know they're there.
Welcome aboard MidnightMan and remember, you can use any quick detailer for the lube needed to clay and I'd suggest buying it in bulk as you can use it for clay lube as well as wiping your car down for a quick shine. Just another little tip, cut the clay into about 3 pieces because if you drop it your not going to want to use it again as it hit the ground and it would be too time consuming to try and cut off the contaminated area. You should be able to clay about 4-5 times per pieces. Well, depending on how bad your car gets and that varies with where you live, what's in the air and how often you wash/maintain your ride. BTW, what wax/sealant did you apply afterwards.
